Originally posted by msc
View Post
problems with speedy =(
Originally posted by vr2004 View Postsorry to give the wrong info... mine also no wood... went to double check again... ya its like fiber glass... ps ps
I'm gonna epoxy that wing together and then reinforce the joint with medium weight Fiberglass !Seriously running out of ...Storage space !
Originally posted by Ghostfit View PostEven with epoxy and that FRP joiner, I've seen a few of them fold in a high speed dive.
Originally posted by vr2004 View Postbtw can use 2.4ghz rite? even if the fuselage is fiberglass??
Seems the CF material will block the 2.4g signal.Seriously running out of ...Storage space !
Originally posted by Ghostfit View PostFar as I know, FG is alrite with 2.4g but CF is a big headache ...you need 2.4g Rx with lengthen antennas that sticks out of the CF fuse by an inch.
Originally posted by vr2004 View Postya man... so the extended wire can solder ourself rite? juz open up the rx n change the wire?
2.4g Rx antenna ...I think you better not try to 'extend' or modify them !!! they are co-axial type and very easy to mess up !
What I meant was that you can buy the Rx with either 'long' or 'short' antenna.Seriously running out of ...Storage space !
Originally posted by vr2004 View Posthaha... ok... then if antena suddenly broke due to crash how??? receiver can't be use anymore?
I broke a few already but solder back...if you can find the wire. This is more prevalent in 2.4 full range receiver or futaba ones.
For radio.... also can try to solder back if else just buy a new antenna wire."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
Note that for my previous post it only applies to AR6000 which is rarely sold now adays. for AR6100s, it is really rare to break the antenna. For 6200s, try it at your own risk.
But since 2.4 antenna so short, it's really unlikely to break, unlike FM ones. I chopped up my FM antenna while doing motor test, lol."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
