MPX Fox chuck glider conversion
    This article is extracted from Sep08 issue of Model World. As promised, I'm attaching it for the sake of MPX Fox owners who want to convert them to R/C versions. Have fun!
    Page 2
      Pg 3
        This is not the only article about converting the Fox to R/C.
        Check these out as well, although I'm sure there are more;
          Another thread on the Fox.
          http://www.rcgroups.com/forums/showthread.php?t=807898
            Very interesting plane
            I'm Remotely Controlled ...
              I have a copy of the mag & I have also just gotten hold of the Fox. So going in for the conversion
              BTW those who like to get the Fox, the stock is in. Only see a few pcs left when I get mine
                Joed, get from where ?
                How much is it ? I am interested to convert one for project.. OK me newbie, but like to experiment.
                  Can still get from NTC. It cost less than $20. The motor & ESC can buy me 3 or 4 of this
                    Yah, but motor and ESC alone can't fly. They still need an airframe, cheap or expensive.
                      What is an airframe ? Do you mean the spars that run through the wings etc.. ? I have no problem doing these stuffs.
                      One question though...
                      9g servos OK ?
                      What motor / prop setup If I want to keep it as a slow powered glider ? Slow as in I don't want speeds of a zippy EDF plane's speed etc... enough for flying in small air spaces such as football field etc.
                        9g servos OK ?
                        An airframe means an aeroplane. As for motor/prop setup, I can't tell you since I have not try it out myself. But generally, you can slow down the plane by using a prop with lower pitch.
                          I'm using a 10g motor, 2 x 5g & 1 x 9g servos, 8A ESC, 2S 360mAh battery, 6x3 folding prop, Corona 2.4G 4ch rx.
                          My pictures are http://www.rcgroups.com/forums/showp...&postcount=251
                          Oh... those were the initial mod with rudder and elevator only. I'm now changing it to individual aileron servos and a elevator servo near the tail.
                            Nice, good job. What was the sanding drum on the dremel? Is it the one that looks like a lollipop and used for grinding?
                              Yup.
