Setting up a cosair with a Saito 82, and to make it more 'scale', I'm inverting the engine and setting it up 'upside down', which I think is commonly done.
Problem is, with this setup, the Fuel tank (midpoint) would be quite a bit higher than the carb. It should be slightly below it so it doesnt flood right?
Is it absolutely Necessary that the tank be slightly below the engine?
Any other solutions?
