i am currently using a Ripper Brushless Motor OBL 2924/11 motor from thundertiger and the specs are:
Specifications:
Voltage Range: 6-10cells, 2-3x Li-Poly
KV rating: 1100 RPM/V
Dimensions Dia. x L: 28.5x24.1 mm (1.12x0.95 in)
Shaft Dia.: 3.175mm (0.125 in)
Max efficiency Current: 4-12A
Current Capacity: 14A/60s
Internal Resistance: 180m Omph
Propeller Recomended: 8x3.8, 8x6, 9x6, 10x4.7
Weight: 43g
and BLC 40Amp ESC
Specification:
Product Name
BLC-40
Product No.
8041-A / 8041-H
Voltage Range
7.4~14.8 V (2~4S Li-Po)
Resistant
0.0048Ω
Continuous Load (5mins)
40A
BEC Voltage
5V
BEC Current
2A
Over Load Protection
Temp. Protection
Setup Procedure
Digital
Governor Mode
Yes
Dimension (mm)
52 x 24 x 7.9
Weight (g/oz.)
27 /0.95
Currently, its on my E-Starter and i want to get a 11.1V battery.. i wanted 2200mah but its 209Grams. people said its too heavy. any recommendations on what mah or hw heavy it should be?
Specifications:
Weight: 43g
and BLC 40Amp ESC
Specification:
Product Name
BLC-40
Product No.
8041-A / 8041-H
Voltage Range
Resistant
0.0048Ω
40A
BEC Voltage
5V
BEC Current
2A
Temp. Protection
Setup Procedure
Digital
Governor Mode
Yes
Dimension (mm)
52 x 24 x 7.9
Weight (g/oz.)
27 /0.95
