Advise needed for a project to place GPS in a Rc plane.
    Hi all..
    Anyone can advise me on a plane or a heli that is big enough to place additional circuit and a GPS reciever which weight roughly 200g? Preferred plane will th EP and foam will be best.
    Thanks.
    Can explore using Eagletree V3 logger & GPS expander, it can fit almost any plane. Small & light, less than 50g.
    Usually high wing plane got spacious fuselage, would recommend Cessna.
    Can check this out, big & spacious
    cheers
      Hi. Thanks for that advise is there any other planes i could look at?
      Is there also any beginner heli that is able to take that amount of weight?
      Thanks
        For the weight that you mentioned, probably a Multiplex Cularis.
        It's a 2.6 m glider, can go darn high, can go darn far on low power.
        Thing is, you shouldn't be a beginner to meddle around with this full house glider.
        But since you're talkin' about GPS in a plane, you probably are not a beginner in the first place.
          Yea not really a beginner but i jus started flying about 6 months ago, now doing it for my poly project.
          Thanks.. Any idea where I can get that glider?
            NTC but not cheap hor
              Instead of a Cularis, you might want to settle for a smaller cousin - Easy Glider, wingspan 2.0m, very steady plane. To take up the payload of 200g, maybe you want to get the brushless option and also a smaller batt.
              Relax and Enjoy The Hobby.
