Maiden the Edge 540. Very good.
Short take off, fast if you want to or hover landing if you need to. First flight was scary as I was using 10% exp and it very sensitive. On second flight, dial in another 20% still sensitive but after the third flight, 45% exp the plane settle down, very responsive despite 45% exp. I using OS FL70 on 13x4 3D APC, 10 minutes of flight, fuel used was less than half tank. Maybe because I am still running in the engine that I was mostly on half throttle. Didn't like the funky color exhault deflector that I bought as it turn soft, loose and discolored after the second flight. Anyone has better suggestion on better deflector?
The build was very good, very easy plane to build. After 2 evenings, completed the airframe. Everything fit like a glove.
