My latest project the Me-163 Komet from RC-Warbirds
The kit comes as ARF in full composite design. All formers are already glued into the fuselage. The ailerons/elevator are hinged directly with the wing surface.
I got the gray version so the only steps required to get in the air are:
1. Install motor mount and cut small cooling holes
2. Glue nose cone including motor mount on the fuselage
3. Prepare battery tray
4. Install servos and push rods
5. Adjust CG, Fly and then paint (better save then sorry )
After seeing the flight video and the AMAZING 201 Mph this bird did with the help of a rocket motor I opted for the same power setup as used by the guys in the video (minus the rocket engine):
- Typhoon 2W-20 Motor (3450KV and 800 Watt)
- 3S Lipo to start with, Option to go 4S later
- Tsunami 72A ESC
- 2x HS82MG servos for the wings
- I decided not to install a rudder.
First the Video. Check it out:
http://youtube.com/watch?v=rmwLC2bvIlw
More info on the plane can be found here: http://www.rc-warbirds.com/product_i...roducts_id/704
Me-163 Komet
- Tsunami 72A ESC
