Hi, is there a way to calculate which propeller to use when converting from a two bladed propeller to a 3 blader?
the motor i am using is an E-MAX blue sky 2215/25
here are the propeller data (2 bladed) stated on their site:
Voltage Propeller RPM CURRENT DRAW THRUST
12.0V 10X5(Thin) 8180 14A 850g
12.0V 11X7(Thin) 6280 18A 905g
12.0V 1047GWS 7200 16.5A 930g
12.0V 10X4.7(SLOW) 7250 16.5A 950g
12.0V 1060GWS 7800 15A 850g
12.0V 9X4.7(SLOW) 8750 12A 810g
The non, gws propellers are based on e-max produced propellers which i assume are pretty much similar to the normal GWS orange propellers.
After some evaluation, i determined that the set-up i require is similar to that of either the 10X5(Thin) ,9X4.7(SLOW) or 1047GWS
how ever, my choices of 3 bladed propellers are limited to
GWS:
HD8040 / EP1060 /HD9050
I determined that 8040 may produce insufficient thrust for my build, also, the motor's suitability specs do not include 8' propellers...
what;s left is with the 10" and the 90"
however, if i use a 3 bladed 10" by 60 propeller, it is likely that my current may exceed my limit of 18A (based on the table)------ any takes on this statement?
so my pictured best choice would be the HD9050...
i assumed that increasing a blade will decrease the rpm and increase the current flow.
i also assumed that increasing pitch will increase current flow and decrease rpm and increase thrust
increasing propeller diameter will do similar
and vise versa.
any takes on my analysis? i don't really know how to convert, what i have done is based on wild guessing.
GWS:
and vise versa.
