To experienced glider fans, especially for Easy Glider owners, noob question on centre of gravity for the Multiplex Easy Glider Electric.
Usually I will refer to the manufacturer's specs for the Centre of gravity. The recommended centre of gravity for the Easy is 70mm from the LE along the wing root. I measured and mark it with a line.
It is somewhere on the cover of the wingspar.
I am using the stock motor and gear setup, HS-82MG servos instead of HS-81. Feather HS-55 for the wings. 2250 mAh 3s1p Lipos with a 25A Brushed ESC from Electrifly. Obviously the LiPo battery cannot fit into that tiny space for the stock battery. I carve into the foam to slot my LiPo in. The good news is, I haven't CA the fuse yet.
So I dry fit everything together with masking tape and the electronics the plane was nose heavy by about an inch. So I carve a bit more into the plane to push the battery back more. Still nose heavy. And so it goes along the battery slope until the end of the battery is barely 1 cm from the bottom fuselage surface. The best position I got to is nose heavy CG just at the wingspar cover opening (about 1.5 cm away). Now, I think I exhausted the option for battery shifting and am thinking of adding tail ballast to correct it. I already added that ball bearing behind.
Just to note, I got 8 LiPo batts and 7 of them are about same size/weight and all 2100~2250 mAh. So I can't change the battery.
Question 1. Is tail Ballast advisable? Although this plane can fly with quite some weight, RTF at 32 oz~910g and some flew even more at 36 oz~1020g and heavier.
Question 2. What should I use for tail ballast? Got some left over hideous plasticine from GWS kits.
Question 3. Any allowance on the CG point? Some forums I trawl through recommend instead an alternative CG 5mm in front. So I guess it's either 70mm from LE to 65mm from LE. Not much allowance.
