Anyone modified gws formosa 2 landing gear here ?can give any info b'cos the original provided form gws is really suck ..except the wheel .
Fomosa 2 landing gear problem
[QUOTE=msc]http://203.124.102.59/forum/showthre...=formosa+no.29
Hi Bro,
Have a look at my landing gear here. You can either buy the CF gear from the local hobby shop, or order it from UH.
MS[/QUOTE
appreatiate your info .i will try to get one like you too .I believe i can fly ....
Originally posted by mschttp://203.124.102.59/forum/showthre...=formosa+no.29
Hi Bro,
MS-Ehawk 2000 Pro
-Mouton 1600 EV
-AMD micro chili
-HK Kinetic800
-SF Learjet45
Originally posted by Touch n Gohi bro, which part of the wing did u mod the LG to? is it at the wing attachment point? i was thinkin of putting it at the front of the attachment point..
At the Leading Edge of the wing belly. The CF gear assembly was sub-assembled, sandwiched with ply. The wing belly was cut out and the thickness of the gear cut-off from the foam. The foam cut-out is then epoxied back.
The shape of the wing belly remains the same.
Also, the wing-to-fuselage attachment was modified with 2 carbon rod that intrude into the fuselage.
The trailing edge mounting screw remains the same.
I did not take more pictures, but if you examine the picture in the post properly, you can see the completed job.
Happy modding!!
MS
Originally posted by mscAt the Leading Edge of the wing belly. The CF gear assembly was sub-assembled, sandwiched with ply. The wing belly was cut out and the thickness of the gear cut-off from the foam. The foam cut-out is then epoxied back.
Happy modding!!
MS
the quality is good .the gear is made from stong aluminium and not easily bend ,the important it's light, fit nice with my formosa II .It really worth spend my 19 dollar .will try out this weekend
