GWS engine mount stick
    I'm looking for a replacement for the GWS engine mount stick which is 10mm x 10mm thick. Any recommended hardware shop which I can find the above mentioned or any recommended wood type for the replacement.
    Thanks for viewing
    Originally posted by Fn5s
    Thanks for viewing
    NTC sells 3/8" x 3/8" hardwood. Comes in 16" length if i rem...JH also sells precut ones... If u're in a hurry, get it from Artfriend though it may cost a lil more
      pips also has it. but if you're looking at materials you have at home, you may want to use ply to make a fire wall type instead?
      if you wanna use the stick type, you may wish to consider putting a mod like this:
      Fubata 7C 2.4 + T6XAs
      Charger- Turnigy AC6
        Thanks for viewing
        ArtFriend - 3/8x3/8x24", just got it for less than $3.
        MS
          If you are buying ur 10x10 stick from NTC make sure you get the hardwood version and not the balsa version. That is too soft. Cost under $3 and u can probably make 8 pieces from it.
          Practice makes permanent. Perfect practice makes perfect.
            Thanks guys. Will go look for the stuff this weedend.
