help needed or brushess gear motor
    hi anyone can help? i brought a brushess gear motor from rotor ex1155 4200kv max amps 10 with 25 amps esc, using 3s lipo 1250mah running on tigher moth using size 10.46 blades, after running for 5mins it stop, temp is about 80c. can anyone advise what can be done?
    80 degree? from where? batt or motor?
    wat is your gear ratio? 3:1? 4:1? 5:1?
    do a AMP test and see how much your motor draw. too high amp will spoil your ESC motor and batt.
    try a smaller prop. think your prop a bit big.
