Guys.. any good way to remove the pinion from my dead 350? I don't have a pinion puller.
Removing Pinion
Yar... already tried that... I got the pinion out of the dead motor...
On the good motor... the pinion refuse to budge... and the motor shaft started coming out...
Think it is 5 mm out....
They must have locktite it...
Guess I either have to fly with a 350B or a 400D...
or get a new motor now...huh
3 Possible Solution for you:
1 - Borrow a Pinion puller and pull it out.
2 - Get a long nose piler (Flat one is recommended) and pile/clip onto the dead motor pinion. Use a less than 2mm pin (Or use those damage IPS motor shaft) and hammer the deam motor shaft.
3 - Get a brand new pinion.
Super-Hornet
