Demons' Big Sister Brewing
    It brews in the factory
    The Demon's Big Sister.............Akan Datang......
    Vital Stats.....
    Wing.....1.9M
    Length....1M
    Do you feel the RUSH....!!!!
    POWER!!! when flying?
      Starting with something tame..
      2 x 3S 2100 packs
      14x10 prop
      Neu 1509/1D with 6.7 gear box
      Est AUW - 1.4kg
      Static draw 70amps......really under utilizing the motor.
      Need more voltage to really power this motor....but need NimH cells. 16 would better. Tried the old Siren 10 cell pack and it only pushed to 40amps...
      More cells, bigger ESC which i dont have.....now with lipo, the plane is nose heavy....Problem leh....
      Most likely maiden this saturday!!!
        wow, seein this guy fly will be wonderful. gotta come down early this Sat.
        More Birds, More Luck!!
          wow another hot plane .........
          hehe u can cut down on coffee already......
          one flight in the morning can keep u alive for the day
          will be there with camera ......hope to capture its maiden flight
            oh shuck on course again
            I think I have a new SubC 10 cells matched battery that yet to see the innard of a plane. Will check once back home.
              OK after balancing the plane with 105 grams of dead weight....sigh...the plane is now 1600grams...
              The orginal plane weight with 16 cells is suppose to be up to 2.1 kg....i will take the lightest setup anyday....still waiting for that 50C continous 4000mah pack thats the size of a 2100 pack today.
                wow 4000 in 2100 mAh size ........50C continous
                man that will be the ideal pack for Trex
                  OK looks like the final flying weight is around 1530 grams...I tested her at half throttle tonight and the "breezed" slammed my door shut...
                    Wahaaaaa............
                      Think u can hand launch it in a 3D way
                      is like a rocket except pwr by prop
                        hows the flight? any report?
                          Thanks to Loyn for the magic hands the maiden of the Raketenwurm 2B(RW2B) went very well today. The beautiful blue sky morning was a really refreshing change from the past weeks haze. Managed to do 2 flights. The landing with the butterfly was a non event...slow and steady she floated down into a mound of freshly cut grass . Turns corners like a pylon racer with the snap flaps Holds energy very well....after coming down from a 45 degree dive, she still managed to do 3 loops.
                          Her climbs are with a lot of authority but I would not classify it as super fast. Maybe a bit faster than the Tumeric. But her fly byes power off screams are little gentler than the Siren while holding energy very well!!!
                          As with the Demon, when you fly her away or directly toward you..she disappears due to the thin profile....a bit scary.
                            sounds great!!!! now fly higher and dive!!!
                              Re brewing again after the mid air collision......
                              Chinese New year project
