all about funjets
    Originally posted by TTT View Post
    Hi bro,
    Motor specs as attached below:
    http://shop.rotor.com.sg/show-detail...FA8AAAB7}&pn=1
    3/4 throttle is required because of the 4.5 x 4.1 prop don't have enough thrust at 1/2 throttle.
    Slight torque during launch but easily counted back by little aleron input.
    When Funjet pick up speed at full Throttle diving...
    May i also know what servos are you using for this setup? Is HS-55 enough? Or need at least HS-65HB?
      Yah you can you the high class Hitec...
      But our gangs are cheapo.. they use only HXT 900 servos..
      If you don't crash, the gears won't strip..
        Yeah man, I am also keen to know the flight time with this setup.....
        With a 2200Mah battery... about 4-4.5 mins flight time.
          You wanna risk your FJ on HS55? Think of the G you will be dealing with. Get MG or Carbonite servos please...
          FASSTGot Quard?
            Originally posted by pck View Post
            What is the flight time with this setup? What batt do u typically use?
            I am keen....
            welcome to the club...
            AVOID Turnigy 2200 Mah Battery at all cost.... mine bloated in just 5 flights.. Pui...
            Get a minimum 25C 2200-2250mah battery...
            Recommend Rhino Brand(yellow banana)...
              That's good enuff flight time for me! I am getting abt 5mins flight time on a crappy 2700KV turnigy 2845 inrunner motor with 5.4x4.5 prop. And i still lost to the other guys... Pui!
              I'm going for this setup to try.
              Thanks TTT!
                Yup, I second that!
                  Hey Bros..
                  I hoot sala...
                  The correct prop that should go with the 3500KV should be 4.7 x 4.1 APC
                  Paisei....
                  Can get from Rotor also...
                    If cannot find... 4.7 x 4.1...
                    4.7 x 4.25 APC also ok...
                    Enjoy...
                      Will HS-65HB Heavy Duty Karbonte gear with Ball Bearing do the job?
                        Thanks TTT!
                        Hi, where and when will u be trying the new setup? Can I join u for the testing? I would like to see the perforamce of this setup in action.
                          Yup... My very own FJ is on HS-65HB.
                          FASSTGot Quard?
                            Bro Raven..
                            I agree with you...
                            Germany made Mercedes should go with Germany made Continental Tyres...
                            Funjet should go with better servos...
                            Where you guys normally fly your Funjets?
                            Got Squardon?
                            Should organise a Funjet Only gathering...
                            Then organise cameraman and videoman to be around...
                            Should be quite fun...
                              Bro Raven..
                              I agree with you...
                              Got Squardon?
                              This will be cool, I usually fly at OHR but not there is a construction going on on one part of the field now.
                              Are u still flying ur funjet and where do u usually fly?
                                Bro Raven..
                                I agree with you...
                                Got Squardon?
                                Tampines CD Field. There is a bunch of FJ fliers there. But usually i fly alone.
                                As for the servo, I feel that the FJ demands is much higher den HS-55 can offer; in which IMHO is some what E-sky 9g class... And also for FJ, you epoxy the servo onto the wing. So its rather troublesome to repair a striped gear. Considering the control arms are facing the bottom of the wing.
                                My 2cents
                                FASSTGot Quard?
