How to reverse motor rotation direction?
    Hi guys, like to ask the experts here a qns, how do I reverse the rotation direction of my BL motor?
    Thanks
    Reverse B/L motor direction
    Just switch two of the three wire connection btn your esc & the motor. Try, it should work.
      hmm which 2? I tried switching the black and red, didn't work
        Motor dir.
        It work on mine. there should be 3 wires: typically in red, black & white or blue. try the other one as well.
        Good luck.
          There are 3 wires coming out from your motor. The centre wire goes to the centre connector of your ESC. So the other 2 you just have to switch them around to get the direction of rotation you want...
          Cheers.
          Just because we grow up, doesn't mean we stop playing...in fact, the games just get better and the toys just get bigger...
          "Speed has never killed anyone, suddenly becoming stationary... that’s what gets you!" - Jeremy Clarkson
            Thanks got it to work
