what battery capacity is suitable for nitro place
battery for nitro plane
5 Std servos. I ran with a 700mAh 6V battery that is designed for RC car.
Enough to last for > 1hr... (about 30 minutes of air time, 30 minutes of ground time.)
5std servos, 1800mAH 4V std rx battery, last me one morning of FF, with about 1.5 hours of air time, 1 hour of gound time. Still have capacity to spare.
When choosing a battery, look at what servos are you using, and your flying style (3D? Relax flying with mild aerobics? Pattern?) This will determine how much energy is drained per flight.
Also, do consider the plane's CG and wing load factor. You won't want buy a high capacity battery and end up having a plane with a higher wing load (1/2A nitro planes).. or put a tiny battery and then realise that the plane is tail heavy...huh
