Got an cdrom brushless from rotor, it say outrunner 1500KVA. http://shop.rotor.com.sg/show-detail.asp?prodid={06B187C0-F03A-45A8-9D1F-88EAC27CC5A7}
I use prop 0843, Hobbywing 18A ESC with:
1) 730mah TP 2S: When I go full throttle, it will cut off with current up to 9A-10A.
2) 2100 TP 2S: I can go full throttle without cutoff with current only at 5A+.
Why the current is so different using 730mah and 2100mah TP? I attribute the cut off using 730mah is the battery C rating at 13C continuous for 730mah compare to 15C for 2100mah.
Another observation is when using cdrom brushless, the startup is not smooth and you need to full throttle to get the prop to spin properly, then the throttle input will be linear with stick input. Is this normal ?
Jonathan
Jonathan
