How does this ESC & Brushless combo look? Quite good deal for $69 and I can use my 3S. Only problem is how to mount in the easy star? Also i think prop need to change. Any advise?
ESC For EasyStar
Originally posted by KamI already feel that the easystar is abit too big! thats why intially i was deciding whether to get the spacescooter or easystar, then seems that vote went to easystar.
You can use the default motor with a 2S lipo, or go brushless and use ur 3S (think it can go vertical)
And the best thing its < 1/2 price of the easystar
Originally posted by KamGP1100 are wat type of batteries? 7 Rechargeable AAs soldered together?
I dun have charger for nimh thats why looking at lipos.
BTW, which GWS ESC, went to webpage but alot of models... ICS, GS, E etc
Originally posted by KamYes, realise that 2S too low V & 3S too high for the motor. Wat about alternative motors that can support 3S, then i can use my existing 3S from my heli and save money from the lipos? Also will the recommended motor be a direct fit into the motor cavity?
Are these the GWS u referring to:
1) GWESC400 ICS-400Li
Originally posted by KamHow does this ESC & Brushless combo look? Quite good deal for $69 and I can use my 3S. Only problem is how to mount in the easy star? Also i think prop need to change. Any advise?
Honestly, my experience with the TT super cub has not been that great. At $55 from rotor is is quite cheap. Unfortunately, the gearbox is terrible. It is also tends to tip stall VERY easily if you go a little overweight. A crash will result in the fuselage breaking at the nose section. If you buy this, best option is to change to a GWS EPS-350D drive and use a bigger prop which will give you more thrust. With tat drive, a 2s(approx)1200mah lipo will give u ballistic peformance. Trick is, KEEP IS VERY VERY VERY light!
Originally posted by ArtyspecYou got 2 options if you would like to use 3s. Somesay that you can use the 7.2v Multiplex 400 brushed motor for 3s.(It is direct replacement and costs 15bucks from NTC). Second option is that you could go straight to brushless. Mega 16/15/4 or Warp4 4t or Multiplex brushless will do good.
So, I'm planning to run 3S and fly it as stock as possible. I will probably get the C-20 ESC together with the kit from NTC, then see if they have the motor.
I checked with the lady there the last time but she did not recommend the (7.2v Multiplex 400 brushed motor for 3s) motor though. Nonetheless, if dun have, i will just run the stock motor @ throttle max 1/2 stick (anyway i found out that its just $6).
Will get the plane up as stock as possible then further on when i have it built and flying then can judge how extensive the mods need to be to accomodate the upgrades.
Not a good idea to use 3s on 400 motor. motor will get hot and melt the foam, even if you run half throttle. and eventually motor burn and risk of batt blooted.. me done that and experience b4..
think it's better to invest in bushless motor and esc, there power is there and i didn't regret it since.
modifying ez* motor mount is hard work. Yes, you do need to gear most inrunners a little bit to drive 5" props. BTW, multiplex 7.2v 400 motor is $15. (german wad...). But if u want the least hassle brushless setup, go with the mega 16/15/X or Warp4 Xturn. Those are drop in replacements.(They are inrunners and do not need gearing)
Just an update everyone,
Purchased the easystar yesterday together with an esky esc (hope it holds). Also picked up 2X2S from JH. These batteries are not like the normal 2S used in micro heli. Its bigger and is rated at 1600mah (12C). I hope they are ok, esp with the nose light easystar.
I have just completed assembling the plane tested the CG. Surprising, i anticipated the need to add lead to the nose. But when i push the 2S2P all the way to the front, it was nose heavy... by quite alot.
I moved the battery to near the centre of the canopy mounts to achieve the desired CG. Now i'm waiting fr my tx batts to charge then will go for a test flight. Wish me luck, and thanks for all the advise given. I will update with the maiden soon.
