Bought some cheap planes in KL.
hi yves,
the plane is not foam? if foam and cut.
I did saw someone add in alerion into his plane, same concept could be use.
he just cut a piece of plastic (think and firm enough) and stick on the wing (u can do tat on the tail).
He also used http://www.jethobby.com.sg/cgi-bin/e...19&cid=7&idx=1 to attached the plastic to the plane to make it movable yet attached....
TT Cub (Destroyed)
Space Scooter (Ready for maiden)
Happy Boy (Building)
Ofna Hyper 7
The plane is a foam plane.... does it make any difference if i just cut or i uses hinges.........Originally posted by Newflyer1hi yves,
Yo Bro, welcome back looks like u had a fruitful trip eh
, the hinges is used to connect the aerlions, rudder or elevator to the plane. You can use fiber tape too.
Once you cut out the aerlion, rudder or elevator, think need to sand 45 degree so that after you join them back to the wing, it can still move up and down, or left and right.
Originally posted by kenshinzYo Bro, welcome back looks like u had a fruitful trip eh
Still not back.......
still in KL.... flying to dubai after that..... Will experiment that after i return......... thanks
if dun wanna cut 45 degrees you gotta leave at least 1mm gap before taping it togetherOriginally posted by kenshinzYo Bro, welcome back looks like u had a fruitful trip eh
Which character are you test by
hahahaha no lah bro..... 2 only... just took a walk around on weekend adn saw the place at 50% discount so just grab lor.... most probably will sent it back home first... carrying it around isOriginally posted by joedWow great!
You flying to Dubai with 3 planes
cool! Look like you enjoy your trip.
See ya back home soon & down at the field. Take care.
see you soon....
