What Nitro Plane to get after E-Starter
    Hi anyone can reccomend what is the 1st nitro plane to get after flying E-starter? What size is good? Would love to start nitro leh..
    Get a 40 size low wing Phoenix Scanner! This is a low cost trainer plane.
      Maybe your next question should be " how do i get started with nitro planes?"
        scanner!!! flies like the estarter: a floater as well.
          Care to share a total cost to get the scanner off the ground..?
          just curious..
            This is just an estimate.
            Plane:
            1)Phoenix Scanner - $110
            2)OS 46AX Engine - $185
            3)Servos x4 - $100
            4)Reciever On/Off Switch - $10
            5)Reciever Battery - $30
            6)Reciever - ??
            7)Fuel Tubing - <$10
            8)Fuel Filter - <$10
            9)Battery Indicator - $15
            Field Equipment:
            1)Glow Starter -??
            2)Enginer Starter -??
            3)15% Fuel - $28
            4)12V Battery -$30
              Hi Boonie,
              Before you go into nitro, it is advisable that you decide where you would be flying at and whether there are other experience guys who can help you out. Perhaps you can go and recce first. And play it safe, okie?
              Cheers.
                Glow starter (a.k.a glow heater) range from $10 - $40. Pending if you need to buy the charger, the capacity, and if it has a meter built in.
                Anyway.. another point to consider is, if you have transport to bring you to the field.. and if the transport you taking can accomodate the plane..... (don't assume it can fit into the car boot).
                huh
                  hmm...where to get 46ax @$185? Went Rotor was quoted $230 leh....izzit SHS sellin $185?
                    you can get SHS price list off their web site.
                    exact price they listed in Sept 05 is $185.60. It may differ now since the price list is already 3 months old.
                    huh
                      thx Nic
                        Thanks for he info...where to check out the 40 size low wing Phoenix Scanner??
                          SHS...Id recommend the scanner too...flies good..and very forgiving
                          TREX 500 ESP
                          Futaba T12FGH
                            You guys good lah! from estarter to low wing nitro plane sure or not?? I would suggest to get a high wing nitro plane 1st as there is alot of difference in electric and nitro, 1st is the speed next is a low wing is not as forgiving as a high wing plane, crawl first than start to walk lah.
                              Do take note that nitro planes fly considerably faster than what most will be accustomed to for an E-starter. landing needs more room as well.
