Hi all
Yesterday me and HotRod took my P-51D Mustang for a first test flight at Yishun Centre.
Test Flight #1:
First flight, after hand throw it somehow just shoot up and stall and fall down head first.
Damage: Motor bracket (Screw) broken. Can be CA back.
Diagnose: All seems ok. Trim looks good before flight. CG look ok but suspect tail heavy or CG out.
Fix: Temp fix motor and move battery a bit deeper. Offset elevator to go up (Nose dow).
Test Flight #2:
After hand throw, it goes up and manage to level abit and it turn right (Wind blow). Then about 1second later, it goes up again (After I level it from wing blow). Try to fight back but stall again and hit the ground (Grassy land) head on again.
Damage: The whole motor bracket goes all the way in. Head open up like durian.
Li-Poly goes all the way in. Break propeller. Main wing secure screw nut area torn off. Canopy (Form area) break a bit. Wing got scratches a bit.
Fix: Go home and fix.
At home last nite: Fix motor compartment, Epoxy the Head. Glue/Epoxy those crack area.
Run out of Main propeller (Bought a wrong size spare..Smaller). Then modify a bit by putting 2 propeller (EP 5035) instead. Also notice the Elevator servo signal are in reverse!! Shit!. Fix back everything. Realign CG (Purposely make head a bit heavy by moving Li-Poly all the way in)
Test Flight #3: Hmm... Today cannot test flight because going out. Thinking of doing it this come Saturday again if possible because Sunday (August 15, 2004 morning got something on so cannot join you all for Funfly... Unless it is on Afternoon or Everning)
Super-Hornet
Test Flight #1:
Test Flight #2:
Super-Hornet
