I would like to share my building experience of the GWS Tigermoth (TM) and hope those TM lover our there find it useful.
Before start, just some commend about the GWS TM. It is not too scale by itself hence some work are needed to fix it. Example are back part of the upper fuselage should be rounded off, wing of TM should not be stright, landing gear is too weak and out of position, aileron control rod may cause stress on servo due and finially reinforce the fuselage especially the front part with the land gear.
OK lets start....
1) Cut and sand fuselage to shape
2) Sand all part to smooth......step to prepare for fiber glassing
3) reinforce the fuselage ....I used cheap hard wood instead of carbon rod
OK lets start....
!!! Another great piece of work from the Master
......time for clean up
