I've been fascinated by scale gliders since years ago. I own a few glass slippers by now but they are a little too expensive to do some experiments on. I longed to try aerotowing and also wanted to try to fly a scale glider at Sedili. I wish for a cheaper and smaller plane to start off with but with so many uncertainties, I decided to scratchbuild a 2 metre scale Duo Dicus.
Since the airframe is meant to be sacrificial if any mishap were to happen, I decided to go for blue foam construction for the fuselage. As for the wings, the most accurate method of building such narrow wings that I'm capable of, is of balsa sheeted white foam wings.
I have a piece of 2" blue foam, but the flatness and surface finishing is far from perfect. There will be a lot of preparations prior to hot wire cutting the basic fuselage profile. But before all these, the first thing to do is to cut the templates.
The plan is drawn with Autocad and printed in A4 sizes. I aligned the A4 sheets with a steel ruler, pinned them down and joined them. The patterns were rough cut, sprayed with 3M77 and pasted on hard cardboards before being cut into the individual templates.
