hi, anyone here ever use a edf 64? wads the performance like? can it be used with a gws a-10?
edf 64
Originally posted by victorhi, anyone here ever use a edf 64? wads the performance like? can it be used with a gws a-10?
EDF 64 is a bit big for GWS A10..
Its can take only 50 or 55 EDF.
Try wemotech micro fan.. it fits well..
ans with 4200kv or above motors..
it will shoot like a rocket man..
where can i get the wemotech duct fans and how much are the motors?i also saw this 12mm brushless motor (can be used with edf50) from acehobby but i dont know if it is suitable for a-10...if i use brushless motor for a-10, can i use a y connector to connect both motors up to the esc of must get u escs?plz advice...thx..
victor
Originally posted by victorwhere can i get the wemotech duct fans and how much are the motors?i also saw this 12mm brushless motor (can be used with edf50) from acehobby but i dont know if it is suitable for a-10...if i use brushless motor for a-10, can i use a y connector to connect both motors up to the esc of must get u escs?plz advice...thx..
victor
For brushless set up, you will need 1 ESC for 1 motor.
As for the motors, perhaphs you can try the Himax 2015-4100 motors or higher KV motor.
If you are more into relax flying without much aerobatics. I think the stock brush motors with GWS55 fan will do the job.
i was at rotor then i saw tis motor here .
can it be used with a edf 55 shell and fan? does it fit into the duct fan? the diameter of tis motor is 20mm but the diameter of the hole in the edf 55 is 25mm...will mounting the motor be a problem due to the different screw holes?plz advice...thx...
victor
Originally posted by victordat means i will still need to use 2 batts rite? but on tx is 1 channel as throttel rite?thx..
if not use a higher amp batt(depand on the size of the fuselage) or parallel them.. red(+ve to +ve) black (-ve to -ve) that should do the job.. there is only 1 channel for throttle on receiver.
55 mm edf
Hi Victor ,you can use the Himodel 55mm EDF from jet hobby at S$12.00.
match well with the Himax 2025-3.2KV(long body 37-40mm long type) or the walkera 20-40 3.2KV.
450gms of static thrust at 12-13 amps on 3 cells lipo is possible with this setup. Can always experiment with other setup
Problem is the grub screw is quite crappy. You need to check and tightened every now and then.
Another thing, the 55mm EDF from himodel do not have the butterfly mount.
If not ,go for the better Wemotec fan
This EDF is good for model that weghts 450gms or lower.
All the best.
Babylon5
victor
2025 5400kv
Hi Babylon,
Spoke on the other forum.
On reading this, would my 2025 - 5400kv motor work on a 55mm EDF on 3 cells?
Will the high current kill the motor?
Am thinking of using it on a 55mm EDF on 2 cells, would it be efficient enough?
Any idea of the amps for this setup on 2S and 3S?
Thanks for the advice.
Ken72.790 MHz
WeMoTec Micro Fan can be bought locally here: www.rc-warbirds.com
Check the shaft diameter of your motor first to make sure you get the right adaptor when you order your fan.
