Do share how these mini perform. Some videos will be good.
Very tempting indeed.
Hi Bro,
I own 1 of the mini EDF T-45. Got it from aerosmith and i must say its great! Quality is gd, all servos, motor and esc are preinstalled so it jus took me abt 1 hr time or less to complete it, fan is smooth too. Cg and throw from the instruction is accurate.
Had 2 flights yesterday with a 1000mah 3s and a 850mah 3s batt. The T-45 can float well and speed is jus nice for me, i jus started flying EDFs so might be consider slow for some of you guys. But it flies well with its stable characteristics.
Highly reccommendable, tempts me to buy more of this Mini EDFs. Cant get the plane of my hands
I build the Mini F-16 into a pusher.
I put a 1780 kv small motor with 6 x 5 prop on the rear.
First flight, I put equal throw for the aileron and the elevator, but not enough up elevator, cannot climb. (Note that there are only 2 servos on this plane. Aileron and elevator are mechanically linked.)
Then I changed it to double the throw for the elevator and problem fixed.
Roll was a little twitchy and landing was little too fast.
Today I added HK401B gyro on the roll on 15% gain, very little only. This stabilized the roll axis quite well. Also I adjusted the motor angle slightly. Climbs very well now.
However it falls out of the loop at full throttle.
Possible reasons,
1. Prop not fast enough, 6 x 6?
2. The aileron moving up together with the elevator makes the plane slow down. I could reduce the aileron throw.
Possible reasons,
Hi ET, have tested your existing power setup with a larger capacity battery and run outside the aircraft first to see if it can push your aircraft?. The small capacity batteries might be problem why the aircraft is not performing well.
If you use 6x6 prop , the systems will draw more current and the small capacity LIpo will just be more severely taxed with more current than it can handled. Just my 2 cents.
Today I just test fly again.
The motor was dumbed down to 60% in my throttle curve, now bumped up to 75%. At 75%, now have enough power, the looping is now much better.
The battery compartment for F-16 is too small for anything larger than 1000 mah. Other miniEDF may be have larger compartment.
Glad you sorted out the problem. Ah... regarding the battery compartment. The china made plane usually have undersized battery compartment.
Let me relate this real story...
My friend bought a mini spitfire recent that only allow 2s 1200mah slim type battery to go in. The c.g of this particular spitfire as indicated on the manual is incorrect. As a result he has to add 60grams of lead at the nose.
60grams =almost the weight of the 1200mah batteries. With the extra 60grams the planes flew very well and glide pretty good but with 2S the flight time varies from 2 minutes to approx 4minutes before noticeable power lost depending on the batteries state.
No fun at all!
The plane should be re-designed and flown with a 3S or 2S with a lager capacity.
In the first place why not made the battery compartment bigger to cater for larger batteries. This allow some freedom in the choice of batteries and allow shifting of the batteries to get to the correct c.g. It also save some manufacturing cost as less plastic materials are use in molding the plane(if a bigger battery space are cored out ). I thought of getting the Spitfire but now change my mind.
Sorry to divert a bit.
60grams =almost the weight of the 2s 1200mah batteries. With the extra 60grams the planes flew very well and glide pretty good but with 2S the flight time varies from 2 minutes to approx 4minutes before noticeable power lost depending on the batteries state.
No fun at all!
