Help?Why i power my throttle and one of my elevator also going up&down?
    Dear all bro
    Need help from expert
    My F15 eagle from starmax
    Why i power my throttle, one of my left wing elevator also up/down like crazy?
    And after i off my throttle, the left wing evaator cannot function?only right evevator can use only?
    Why?
    Anyone have the same experience here?
    Pls help....i new here
    hmmm
    i'm assuming u r not using y-cable for yr elevators. make sure yr mixing is right. seems like u r mixing throttle with yr left elevator. use channel 2 (hitec/futaba) as master for 1 servo and aux channel as slave for the other servo and mix p-mix them. hope it helps. better to use a y-cable so that u dont have to mix anything.
    Flying is all that matters...
      hmmm
      if u r using y-cable, make sure its not between yr left elev and throttle. it shld be between yr left elev and yr right elev
        Seems to me like the left servo is gone... Try switching the 2 elevator servo channel to determine whether is it really a servo problem.
          Thanks bro...will try it tonight
