HI! Guys,
After reading a lot from Astroboy on his F-15 Eagle thread and it really make me interested in foam project now. So I go ahead with it, but before that I read some post from other website most of them did it and flown very well both F-15 Eagle & F-18 Hornet and I off for the Hornet bug, because since young I like the F-18 very much so I 'll do this plane. A lot of them did it with pushers system and I think hey! why not do it the ducted system which looks more and feel like on right?
So I got my F-18 Hornet plan already and by using the template everything seen very fast with-in 4hours cutting & glueing plus sending down the fuselage nicely. I did some changed on the F-18 template to look more like the real BUG. First was the front fuselage where the two hole to fit in the strake, the 1st strake hole I keep it the same way but the 2rd strake hole I bring it down another 5mm so it will look more like the real BUG. Next is the rear fuselage where the main wing is sitting on it, I bring down 10mm because I 'm going to reinforce 2 wing instate of 1. As for the 1/4" balsa triangle wood I replace it by using the foam, just cut out 5mm X 5mm and stick them on. Weight will be a issue on ducted system so she 's gonne cut down some weight
Ducted fan will be the Super Flying Model(SF) Turbo Fan System and will be running on Brashless motor GS BL B20-40-7, both are from JetHobby but too bad now they are out of stock had plane an order already end of the month will come I hope ESC & Lipo batt I still not sure yet must see how it 's go first any advice from you guys? Was working untill very late start at 10 plus finish around 3 in the morning so want to sleep
Today very busy so only now start posting my project up come
That all from me now got to go home now, maybe tonight I 'll do some more update if I can my eyes now looks like those Panda bear from Chain now
