Hi guys, i am starting on EDF planes and i have some questions. Is it normal if your plane vibrates alot when your throttle is set to the Max? also, does it have this screeching sound. Thx
Rc F-16
You need to check EDF unit if it is dynamically balance . If it vibrates during operation ,it could be the EDF blade is unbalance and may lead to possible blade failure.
If the blade are well balance when you power up, there should not be any significant vibration. a good and well balance EDF has no vibration at max power.
Originally posted by Babylon5 View PostYou need to check EDF unit if it is dynamically balance . If it vibrates during operation ,it could be the EDF blade is unbalance and may lead to possible blade failure.
