F-16 & F-35a Edf
    PM had reply to all bro on the F4U-4 Corsair, anyone interested on the EDF jets? I'm going to 6 of this...... For those seen the video on the F/A-18F Super Hornet knows what it mean hahahaha No lah just joking maybe two if one crash still got one more mah.....
    Jameswilliam
      EDF in this kind of size plus those scale looks and details with scale function don't come cheap, I got lots of PM but in the end some turn away....we're talking about big EDF not small one. The jets run on 6cell so you can tell how big those jets are. Function like 360"VT, Flaps, Lending edge slats, Retract gears, Open/Close gear doors & Canopy plus Colour smoke system Oh, there's even folding wing function on two of the model, the F-18 & F4U. Was it worth to own one.
      Jameswilliam
        Oh! Forgot to add-on one more, Nav lights(LED)
        Jameswilliam
          The size of this range EDF is almost very close to a 1/8 scale turbine jet in any market out there, but to own one turbine may cost few thousand to 10/20K. But The EDF I'm going to get is more cheaper in cost compared to a turbine jet further more they both work on the same function in control. The only thing is, this kind of EDF range as highly-end EDF just look around you wouldn't get any EDF with all the function in one jet. Example you may get only 360"VT and Landing Gears with no gear doors or just a fix landing gears the most.
          Just to let you guys know they came in 3 version RTF, PNP & ARF and the foam is in EPS you can hardly know it is foam anymore really, I got F-16 & F-35 from them before the surface is really smooth & light too.
          For those really interested let me know before I pre-order mine we can bring in EDF to another level, as this is a very rare chance why because I order once from them before on the F-16 & F-35 1 1/2 years ago and never thought I will order from them again. But seens they got so much new models came out that's why I'm on again. So anyone interested better not miss this ride........I say again better don't miss this ride.
          Jameswilliam
            Here's some video on the A-10Warthog, the last video I'll name it No Fish Shrimp(Prawn) also can
            LX A10のコクピットhttp://www.msfc.jp/kenmamuya/
            Jameswilliam
              PM reply bro SkyHawk
              Jameswilliam
                PM reply joed
                jameswilliam
                  This are the rest of the models from the same company, Bro SkyHawk asking me to post what other model then those I wanted to get. I'll post more details pictures on all this jets on the next page, as there's too many to shown plus I'll post video too. Thanks
                  A-10Warthog
                  Wingspan: 1500mm (59 in)
                  Length: 1400mm (55.1 in)
                  Flying Weight: 2450g (86.4 oz)
                  Thrust: >3000g (more than 99 ounce of thrust)
                  EDF Diameter: 2x 70mm
                  Servo: 10 X 9g
                  Retract: Threaded rotary shaft driven(Front Nose Gear Will Rotating When Close)
                  Canopy Opening,Threaded rotary shaft driven,
                  Deploy Flaps, Gear Doors,Nav Lights(LEC)
                  MiG-29
                  Wingspan: 1142mm (45 in)
                  Length: 1514mm (60 in)
                  Flying Weight: 2000g (70.5 oz)
                  Thrust: >2500g (more than 88 ounce of thrust)
                  Drive System: 2x 2100KV Outrunner Brushless Motors
                  Servo: 17X 9g high speed micro servos
                  Cockpit Ejection, Functional Airbrake Flaps,Lending Edge Slats,
                  Landing brake parachute ejection
                  Electronic smoke system with dual colored smoke drop tanks,Nav Lights
                  Dual 360" thrust vectoring nozzles
                  F/A-18F Super-Hornet
                  Wingspan: 1200mm (47.2 in)
                  Length: 1500mm (59 in)
                  Flying Weight: 2750g (97 oz)
                  Servo: 15X 9g high speed micro servos
                  Dual 360" thrust vectoring nozzles,Amazing alpha maneuvers!
                  Functional Airbrake Flaps, Lending Edge Slats,Functional Mechanical Folding Wings With Locking Device
                  F4U-4 Corsair ( Still On Production )
                  Wingspan: 1600mm (63 in)
                  Length: 1273 (50.2 in)
                  Flying Weight: 3100g (109 oz)
                  Drive System: 1 X 400Kv (Diameter 42mm Brushless Motor)
                  Servo: 10X 9g high speed micro servo
                  Retract: Threaded rotary shaft driven,Nav lights,Gear Doors
                  F-22 Raptor
                  Wingspan: 1046mm (41.2 in)
                  Length: 1513mm (60 in)
                  Flying Weight: 2100g (74 oz)
                  Servo: 10X 9g high speed micro servos
                  Cockpit Ejection, Functional Flaps,Lending Edge Slats,
                  Dual 180" thrust vectoring nozzles
                  F-16 Falcon
                  Wingspan: 860mm (34 in)
                  Length: 1300mm (51.2 in)
                  Drive System: 2400KV Outrunner Brushless motor
                  EDF Diameter: 70mm
                  360" thrust vectoring nozzles,Retractable landing gears & doors
                  F-35 EX
                  Wingspan: 850mm (33.5 in)
                  Length: 1272mm (50.1 in)
                  Flying Weight: 1300g (45.8 oz)
                  EDF Diameter: 70mm
                  Thrust: >1400g
                  LED light on the front landing gear
                  F-117 NightHawk Stealth Fighter
                  Wingspan: 800mm (31.5 in)
                  Length: 1150mm (45.5 in)
                  Wing Area: 36.8 dm2
                  Flying Weight: 1200g (42.3 oz)
                  Drive System: 2850KV Outrunner Brushless motor
                  EDF Diameter: 70mm
                  Thrust: 1000g+
                  Servo: 9X 9g high speed micro servos
                  LED light on the front landing gear,Retractable landing gears & doors
                  Open / Close bomb bay for drop bomb
                  Russian Sukhoi Su-47 Berkut
                  Wingspan: 1120mm (44 in)
                  Drive System: 2x Outrunner Brushless motors
                  Thrust: >2500g
                  Servo: 16X 9g high speed micro servos
                  B-2 Spirit Stealth Bomber
                  Wingspan:1600mm
                  Length:700mm
                  Wing Area: 47.4dm^2
                  Flying weight:1550gEDF
                  Drive System:3600KV brushless motor
                  Diametre: 2 X 64mm
                  Servo: 11 X 9gram servos
                  Jameswilliam
                    Videos are on cut & paste from early post plus add-on other models. There's no F-35 EX review sign........sorry guys Anyway enjoy the video
                    Order now at: http://bit.ly/BlitzA-10This is your flight review of the Famous A-10 Warthog! Thanks to my buddy John Asher and his amazing gift, together we a...
                    Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.
                    Order now at: http://www.bananahobby.com/6-ch-blitzrcworks-f-117-stealth-fighter-v2-rc-edf-jet-arf.htmlThis has got to be the best Ready To Fly F-117 Stealth...
                    Order now at: http://www.bananahobby.com/8-ch-blitzrcworks-sukhoi-su-47-berkut-v2-rc-edf-jet-arf.htmlThis is the ONLY SU-47 Berkut on the market that offers ...
                    http://www.bananahobby.com/1886.html This is an exciting review to bring to you! This is the worlds first Ready to Fly Electric EDF B-2 Stealth Bomber of t...
                    Jameswilliam
                      A-10Warthog
                      Jameswilliam
                        A-10 Warthog
                        Jameswilliam
                          Mig-29
                          Jameswilliam
                            Mig-29 (4th picture shown Smoke System)
                            Jameswilliam
                              Jameswilliam
                                Oh.......
                                Jameswilliam
