I own this plane, will check tonight and update you so that this weekend you can Maiden it this weekend ok?
By the way what is your power setup huh? I tried Scorpion 3595kv running on 2250 mah 4 cell on HET fan setup, powerful but flight time very short, then I switch to Topband 2700KV outrunner on 4 cell, enough thrust for proper take off. Save power, longer flight time and battery not so "Siong".
This plane is light can float and can stay in the air even with no throttle input if got strong wind. Fun..
Cheers..
May I know what's the ESC rating (i.e. 50A?) u used on 3595kv runner? Using the same ESC when u change the runner to 2700kv?
Cheers..
hi TTT
i got the freewing motor 4s match with mini fan,power soso~i will look at the cg then reconsider the setup agian.
im okie with short flight time~as long as the f22 not too slow then me and my buddy will more then happy.
