bros,
i'm starting this new thread because i'm a newbie
on the the "DUCT SIDE"
i myself was doing research and study but it's not enough i need additional information from the experienced, expert and gurus of the "DUCT SIDE"
i'm eyeing for a good setup that would be able to provide powerful static thrust from a 65mm-70mm duct fan and i'm using a 4s1p 5000mah
can you anybody here pls suggest which of the three EDF can prodive more static thrust because all their specs are almost the same and lets say we use a 4s1p 5000mah
1. WeMoTec Mini Fan 68mm
2. Velocity WM 400 70mm
3. Tahmazo EDF 68mm
and what would be the best motor kv and esc amperage for the chosen EDF
thanks alot and hope anybody can give me a brigther insight of the matter
jhonº
3. Tahmazo EDF 68mm
jhonº
