True outrunner mtr for EDF
    Hi , just curious to know if anyone has tried using a true outrunner motor(rotating can at the outside) and innovatively found a means to mount into a ducted fan.
    I was currious because I just took out and impeller(70mm dia.) the other day and just fix into a 2.5KV mushroom head outrunner and was amaze at the power generated by this small little outrunner. Unfortunately I having figure out how to mount into the EDF shroud and secure the motor.
    Theorectically if we could find a way to mount this outrunner(high rpm type) into EDF we could realise a very efficient ducted fan systems.
    Babylon5
    if i'm not wrong outrunners is more of a high torque den rpm
    for ducted fan u need high rpm
      Babylon5
      Hi Babylon5,
      Well, Nothing is impossible, a GWS 55 EDF can do over 100mph so to install a outrunner motor for EDF why not, right? (Just kidding, dont take it too hard ya ) Anyway, I had came across this thread sometime last year about outrunner for EDF. check it out http://www.rcgroups.com/forums/showt...t=392297&pp=15
      I hope this link will answer most of your question.
      As wat you had mentioned, the outrunner must be those high KV type.
      but then again, it all depends on wat type of airframe and its weight which you are going to fix on with that.
      Cheers .
        outrunner in EDF
        Yeah , how nice if you could put a 2.5KV outrunner on 4 cells into a 90mm wemotec Fan? What a blast it will produce?
        It won't be long before some guys will do it.
        Just need to access to some machine workshop, a lathe and a milling machine...and a pinch of imagination.
        Some outrunner are high rpm. Some are DIY or custom made from CD rom motors. You can have any rpm if you know how to DIY the motors.
        meanwhile check out website
        Kyosho 550 - 227 watts / 12 Cells NICAD
        Thrust = 28.4 oz..=806.8 grams if 1kg=2.2lb
        or 3.54 gms per watt...real cool man.
        They are using Hackers motor...need to save up to get this motor.
        I am not sure if Kyosho 550 means 55mm dia EDF
        so 460gm of static thrust at 143w(11V at 13 amps) is not unrealistic figure.
        Anyway this is a good baseline to start .
        Babylon5
          Outrunner EDF
          Hi ER69, went to the website. Thanks. Those guys are doing just that. It won't be long before the outrunner become commercially viable
          for EDF application.
          That will be good news for all EDF lover. I am just waiting for somebody to cross the 4grams thrust per watt threshold with the 55 and 70 mm EDF setup...then EDF will rule the sky...just kidding.
          Cheers to the outrunner
          Babylon5
            Babylon5,
            Cyclon has 4000 kv outrunner for fan use, check out this site http://www.cyclonbrushless.com/cyclon.html#Fan
              Cyclon Motor
              Thanks X34 for directing me to the site.
              Would like to find out of the EDF setup with this motor . maximun current, number of cells tried and static thrust if available.Any idea where to get more info. Anyway I will trawl the internet for more info tonight.
              Any idea how much this motor cost and anyone carry this motor?
              Babylon5
                U can check on the spec table or email them. SHS carries the motor.
                  Thru outrunner EDF finally in Singapore
                  Hi please check this link
                  EDF is a 80mm and comes with outrunner motor.
                  Very affordable prices.
                  Babylon5
                    Interesting. The gap between rotor blade and housing looks quite big though.
                      Hi Warbird,
                      another observation.
                      1.)The weight of the fan and motor weighs 104grams. Looks like this is a small outrunner(small magnet) motor. That is why it is taking 33amps and producing only 750grams of thrust.
                      The EDF would have perform better and more efficient is it is fitted with a larget magnet outrunner motor.
                      2.) There is no "butterfly" mounting flanges on this fan. Just wonder how to mount this large fan into your model???
                      Babylon5
                        CA glue maybe
                        All this experimenting costs too much money! I stick to my trusted and well working WeMoTec Fans with Typhoon Motors
                          ETH550 "XF-Fan" 56mm Ducted Fan outrunner motor
                          Hi, take a look at another outrunner EDF from Hobby Lobby see link.
                          Has anyone use this EDF? Would like to know how it performs.
                            Hi guys,
                            Saw a DF specially designed for 28mm out runner in Radar Hobby (Hong Kong). Bought one home and now looking for a suitable outrunner to fit it...
                            Cheers.
                            Just because we grow up, doesn't mean we stop playing...in fact, the games just get better and the toys just get bigger...
                            "Speed has never killed anyone, suddenly becoming stationary... that’s what gets you!" - Jeremy Clarkson
                              Yep.
                              I m using Align RCE BL 3550kV motor on my Interceptor DF unit.
                              Amp draw is around 21.5A.
                              Thinking of trying Align RCE BL 4050kV motor with a different DF unit on Interceptor also.
                              should not be a problem to use outrunner. But must get one with high kV and make sure your motor can withstand the amp draw.
                              Tx: Futaba T6XA 29MHz
                              Planes in service
                              ArtTech Cessna 182, 2nd;Self-Built Flying Wing, 2nd;GWS Formosa I, 2nd;GWS eStarter, 2nd; Interceptor EP, 2nd; World Model, Melting EP
                              Nitro
                              Sonic 30 size High Wing
                              Others
                              GWS DHC Beaver;EPP Mustang P51;
                              BAT Flying Wing; HoneyBee FP: Hanger, still learning to fly
                              Scrapped
                              Hacker El-Bandito
                              Boats in service
                              Negotiator;Destroyer Yamato (tribute to Temannis)
