Hi guys. Need help here. Months back bought a TT E360. Having problem with GT5 gyro so just change off with beast X. Now my problem is that my cyclic servo movement are slow. But when I pitch up and down with collective pitch the movement is fast. Is only elevator and Aileron slow. Tried to set the cyclic respone and control behavior it makes no different. Can anyone tell me what's wrong?
Beast X V3.0
Hi bro, is the cyclic servo movement slow when on ground and rotor not spinning or during hover the cyclic movement is slow? If on the ground slow is normal, is suppose to be that way.Heli
1 - Flip360 quad with APM 2.6.
Plane
1 - Durafly P-51 Mustang - Nice scale details and stable in the air
Tx
Frsky Taranis X9D
Really thanks alot for replying. Appreciate. Yup on the ground. Just found out also from other forum is normal.
So I flew it few times already. during hover, my heli get higher and higher in the air maybe because of the wind.
So I slightly down the throttle. Yes the heli lower down abit but at the same time my heli tube to the real. So I need
Counter back by pushing front. Feels unstable.Is that normal? Or not enough cyclic gain?Cause it feels different from my small heli. FBL too.
Originally posted by ah_liang View PostYou should fly with a flat throttle curve and add some negative pitch to your pitch curve.
Sometimes, even when blades are at neutral, it is very difficult to bring the heli down if the wind is too strong.Heli-ADDICTION:
Originally posted by Xc wong View PostHi guys. Need help here. Months back bought a TT E360. Having problem with GT5 gyro so just change off with beast X. Now my problem is that my cyclic servo movement are slow. But when I pitch up and down with collective pitch the movement is fast. Is only elevator and Aileron slow. Tried to set the cyclic respone and control behavior it makes no different. Can anyone tell me what's wrong?Heli-ADDICTION:
Unstable as in sensitive ?or sluggish,sticky? Or totally uncontrollable,unstable?Hangar
-Extreme Flight 88" Edge 540T
-Extreme Flight 88" Extra 300
-Extreme Flight 78" Extra 300 exp
-3D Hobby Shop Extra 72" Extra 330SC
-Extreme Flight 64" MXS exp
-Extreme Flight 60" Extra 300 exp
-Extreme Flight 48" MXS exp
-Extreme Flight 48" Extra 300 exp
Sluggish. Like slow reaction.When reduce throttle the heli tile to rear. Which i dont know why and never counter in my other heli before. counter back by pushing forward by abit seem no effect. Push more then abit over.
By the way where u guys flying. I usually fly sembawang near north link building weekdays and holland road weekends. Dont know where else to fly
