What is best tool to cut 2mm arcylic sheets?
    Wanted to cut a straight cut for a thin sheet of about 2mm thick.
    Using hack saw is no easy way with poor finishing.
    Btw i got no acess to those huge cutting machine thats why I come here to ask.
    Please advice. Thanks.
    A good way to achieve a clean cut for acrylic, plywood or balsa is to use laser cutter. A 40w laser can cut up to 4mm thickness.
      score the sheet a few times and then "break" it along the line
        Thanks for the reply. The score method works really well.
        The tool to make a deep cut cost about $5.
        Hold to the edge of a table top and break the sheet.
        Mostly I will use saw for any cutting job.
        BTW I am making number plate for the eBike. LOL
