Enquires
    Enquires
    Hi I looking for cnc service and I had some question I like to ask...
    - What is the max or range of dimension tat cnc machine can work on?
    - Is aluminium suitable to work on?
    - What type of file format is possible (*dae,*dwg,*dws*dwt, *dxf )?
    - Can anyone help me with this type of service?
    *this is not the actual diagram just an example
    Your advice and info is greatly appreciated
    The range of CNC machining center is really wide.... on general most industrial is ard 500mm - 1000mm
    We had seen those that are even bigger. Whats yr block size?
    Hobbyist grade CNC machine usually at range of 200 x 300mm or even smaller table travel.
    Mike
      acrylic block 160mm * 80mm * 20mm (length*width*thickness)
      aluminium block 75~76mm * 58~60mm * 25mm (length*width*thickness)
      working depth less than 15mm
        Sounds to be within our machine range.
        Send your DXF file to sales@sgtooling.com , I will see to it.
        Regards
        Mike
          ty mike, i will sent in within this week
