CNC Heli Boom Support
    Requested by JYHELI, heres a preview of a pair of custom boom support.
    Width 47mm and dia. 22mm x 8mm thick AL6061
    Raw material is cut to size using Proxxon FET table.
    After which part is put on Sherline CNC machine for the rest of the operation.
    Mike <br> <br>
    how did you drill the side mounting holes ?
    agaration?
      I use a Proxxon drilling machine and locate manually.
      You can setup CNC G-Code and use a dial test indicator to align the part.
      Then use an edge finder to local the edge of the part accurately to get X0Y0 ... http://shop.sgtooling.com/index.php?...&productId=137
      <object style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/f0od-cp_9dg"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/f0od-cp_9dg" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></object>
        Got my stuff today
        Mike,
        Thanks for getting this done for me....
        Jonathan
          Nice.
          XRB SR Lama
          Robotis Bioloid
          Robot Bear
