what is the different between CNC Mini Mills and CNC Routers
what's the different?
Greeting, the primary difference is in the design of the machine itself.
Router are more for cutting of plates. Eg wooden or aluminum sheet. The plate are secure on the bed and the cutting spindle moves over the plate to cut the desire shape.
For mill, The spindle are fix with the bed moving to cut on the require axis. Typically the part to be cut are of more complex shape as compare to using a router to cut.
Try searching some picture of these two machine to compare the differences.
