Milling the carbon fin or carbon side frame
    HI Mike ,
    i would like to try to mill the carbon fin or carbon side frame.
    Wondering how to secure the carbon to the jig.
    Do i need to bolt it down or clamp it?
    I will be using a vertical milling m/c from my company doing moulding.
    Any advice or picture will help.
    I am only know the basic operation, hope to do it in my free time( Off day )
    Thanks
    Best Regards
    Keepflying
    Firstly, milling carbon material is hazardous, before attempting to work on this material, vacuum/ventilation system is advisable to be in place
    For thin material, the usual way of holding down is to use a clamping kit. This kind of clamping system is design to clamp down thin and odd shaped material so that milling process can be carried out.
    Else you may wish to make a "Jig" from a block of aluminium. Drill 2 mounting hole thru the carbon onto the block. Then secure w M3 screw and you clamp the entire block onto your vise. There you should be able to mill your way thru.
    Mike
      just use 3M double sided tapes.
      enjoy.
      Sondol first talk later!
        Thanks Guys,
        Hope to try is soon.
        Meanwhile will source for carbon sheet and G10 material.
        I hear someone getting from little indian ?
        Will try there first.
        Thanks
        Best Regards
        Keepflying
