What is the thing you need to tap? Tapping is not a difficult thing to do
What you need to do is get a 3.3mm drill bit, drill the holes you need and tap w a M4 tap. Basically tap comes in a set, 1st 2nd and last tap. If you on thin material, whack all the way w the last tap If you are those perfectionist, then slowly go w 1st then 2nd follow by last tap
Provide us w more info and I will see how I can help
