Input Voltage: 10-15V DC
Battery Types, # of cells: 1-10 Nickel-Cadmium cells (1.2-12.0V NiCd)/1-10 Nickel-Metal Hydride cells (1.2-12.0V NiMH)/1-4 Lithium-Ion or Lithium-Polymer cells (3.6-14.8V Li-Ion/Li-Po)
Battery capacity range: 100-9900mAh
Fast charge current: 0.1-8.0A linear, reflex, impulse and 4-step
Fast charge termination: Peak detection for NiCd and NiMH; ¡§constant current/constant voltage¡¨ for Li-Ion/Li-Po; optional thermal cutoff for all battery types Peak sensitivity: 0-25mV adjustable
Trickle charge current: 0-500mA (n/a for Li-Ion/Li-Po)
Discharge current: 0.1-10.oA adjustable
Discharge cut-off voltage: 0.8-1.2V per cell NiCd & NiMH; 2.5-3.7V per cell Li-Ion/Li-Po
Temperature cut-off range: 50-131°F
Cycle count: 1-10 cycles (n/a for Li-Ion/Li-Po)
Cycle cool-off delay: 1-30 minutes adjustable
Output connectors: banana jacks
Review by RCTech
It can run in motors even, does 1-4 cells lipos and it's the SAME price as Triton!
And charge current is 8A over Triton's 5A with GRAPHICAL LCD..
Only lousier thing than the Triton is the NiCd/MH only 10cells instead of 24cells.
And it doesn't do Pbs..
But sadly, no backlit LCD.. hee..
