Hi All,
Here's my new project home built "IFO" with minimum cost. I intend to build it really slow and steady whenever I've got some spare time (since much are spent with family).
I won't say I "designed" this plane since there are already so many out there in Spore such as RCkite, Firefly, and the orginal IFO from (www.wildrc.com).
More than a trial and error to balance the CG, I believe any plane will fly as long the basics are present and CG balanced "roughly".
So for those folks out there wish to built one too....be patient ok. ..let me do a few test flights to confirm the dimensions,CG and config, then I can post the plan eventually to share with us in DH.
I want to keep this plane simple to built, real cheap...and fun!
here are some pics for the start.
Roughly outline the shape of the wing on a flat compressed foam get from Artfriend (6mm thick), sorry the dimensions not confirm at this stage (you can figure out from the pics)....but just by rough guage of the shape of the wing and space clearance in front of the motor.
use masking tape to hold the carbon rod in place.
