Hi guys. I'm selling a beautifully built, tunes and test flown quad.
This is the Ecks frame, from Sweden. http://www.ecksstore.se/#!frames/cs0c
These are the components used in the build,
Ecks frame
Keda 2730 motors (1500kv, super lightweight motors for longer flights and efficiency)
Special firewall mounts for the motors for a lower profile
AFRO 12A ESCs (SimonK flashed)
KK2.1.5 FC (great for beginners and experts alike, can change settings at the field with the on-board LCD screen, no computer required)
Low voltage buzzer for the KK2.1.5 (no need to use a separate low voltage alarm)
Power distribution board (great for adding/removing components, small footprint)
8x4.5 props - 4pcs
3mm collet adapters for the motors
LED strips installed on the front and back to help with orientation
OrangeRx R615X Spektrum/JR DSM2/DSMX Compatible 6Ch 2.4GHz Receiver w/CPPM
All cabling and soldering done
Battery strap
Finally, the quad is built, tuned and test flown. Flies beautifully. Great for sport/acro flights and good fro beginners as one-piece wood frame is very tough.
Only flown to test/tune.
Selling for $325.00.
I also have batteries and extra props if needed, at extra cost.
Whatsapp 97704140
Collect at Pasir Ris MRT. I can demo it for you before you buy it.
Ecks frame
8x4.5 props - 4pcs
Battery strap
Whatsapp 97704140
