WTS : BNIB Seagull Pilatus PC-9 Size 75-91
Description
Brand: SEAGULL MODELS
Wingspan.......................................63 in.....................160cm.
Wing area......................................647.9sq. in.............41.8sq.dm.
Approximate flying weight.............8.4-9.3lbs................3.8-4.2kg.
Length............................................ 58.3 in..................148cm.
recommended engine size............0.75-0.91 cu.in...........2-stroke.
0.91-1.0 cu.in...........4-stroke.
Letting go at $265 nego
SMS 90062589
WTS : New RCG 26cc petrol engine
Engine just run in but not yet install on a plane
With it's easy starting characteristics and reliable low-maintenance running the RCG 26cc is an excellent engine for large trainers or scale aircraft.
RCG quality engines have proven themselves the world over for quality and reliability.
Features:
• Easy starting
• Low maintenance
• High quality and reliability
• Japanese Walbro diaphragm carburetor with butterfly valve
• CDI Computer controlled auto advance ignition system
Specs:
Displacement: 26cc
Max Power: 1.95Kw @ 8,000RPM
Bore/Stroke: 34x28.6mm
Weight: 1122g
RPM: 1,500~8,000RPM
Ignition: DC-CDI computer controlled auto advance system
Carburetor: Japanese Walbro with manual choke
Suggested Prop: 18x8 2 blade
Fuel: Oil/gas mix (25:1 for break-in 40:1 for general use)
Letting go at $140
SMS 90062589
Description
SMS 90062589
Features:
• Easy starting
• Low maintenance
Specs:
Displacement: 26cc
Weight: 1122g
RPM: 1,500~8,000RPM
Letting go at $140
SMS 90062589
