Dear all,
Up for grabs is Durafly DH 110 Sea Vixen EDF jet with retracts. Superbly stable and good to fly.
he DH.110 Sea Vixen was an all weather fighter/ground attack aircraft with a very distinctive and unusual cockpit arrangement, the pilot's cockpit being offset and the observer sitting in the infamous "coal hole" which was virtually blacked out and very cramped. The design actually dates back to the 1940's, which is pretty remarkable considering the fact that the DH.110 prototype was the first two seat aircraft to achieve supersonic flight. However, once re-designed for carrier landings, the new thick wing prevented the Sea Vixen from achieving supersonic flight despite the huge amount of power from the twin Rolls Royce engines.
The Sea Vixen is made from tough EPO foam and is beautifully finished with waterslide decals. As well as looking the part, it is easy to assemble and setup. Being Plug N Fly, the EDF unit, ESC, UBEC and servos are all pre-installed. The DH.110 is pre-fitted with superb, scale-slow servoless retracts featuring a metal trunnion and a very positive lock. This combined with the beefy struts and large wheels make this jet perfect for almost any field!
Jets are about performance and the Durafly® ™ Sea Vixen is no exception. It handles superbly, tracks well, offers a nice turn of speed at WOT and has excellent slow flight capability thanks to the massive amount of wing area. When you combine this performance with the real presence and ultra-scale detail, the end result is a brilliant model that will satisfy jet enthusiasts and scale pilots alike. The DH.110 even comes complete with optional high-detail drop tanks and ordnance.
Fast, stable, reliable, easy to fly and dripping in scale details, the Durafly® ™ Sea Vixen will be a real show stopper at any airfield!
Specs:
Wingspan: 1000mm
Length: 888mm
Flying Weight: 1500g
EDF: 70mm with 2950kv 2836 Brushless Outrunner Motor
ESC: 45A w/UBEC
Plug Type: XT60
Servo: 9g x 4
Retracts: Servoless Electronic Type
Plane comes with Spektrum Receiver. Just plug your batt and go if you are using Spektrum radios.
Requires 4S 3000-3300mah Lipos.
Priced to clear @ SGD150.
Specs:
Wingspan: 1000mm
Length: 888mm
ESC: 45A w/UBEC
Plug Type: XT60
Servo: 9g x 4
