Retiring from those 'fast & furious' days of flying... see if there's anything you need here.
turnigy signal reverser $3/-
on/off switch unit $3/-
pair of SG5010 std servo 38g $15/-
pair of new power metal servo 17g XL-17HMB $28/-
lot of hxt900 servos $20/-
lot of 4-pin lipo charging plug wire $2/-
white spinner 75mm $3/-
lot of fms 1.4m props 13x8 $10/-
apc prop 14x7 $2/-
lot of prop 13x4 & 13x8 $3/-
lot of prop 12x6 & 12x8(used) $4/-
lot of slow-fly prop 9x3.8 $4/-
lot of prop 10x4 wood & apc 10x7 $4/-
lot of prop 9x6 & 9x7 $3/-
set of grass landing wheels 3 x 4.5mm $2/-
lot of gws wheels + metal struts $5/-
dubro metal wheel axle 2" x 5/32" $2/-
set A mini retracts + suspension landing gear $50/-
set B mini retracts + suspension landing gear $50/-
pair of 'head' pilots $6/-
pair of edf pilots $6/-
lot of mini warbird pilots $8/-
1.4m warbird pilot $5/-
lot of HY9x7 3blade props (not for quad!) $10/-
10blade edf impeller 4mm $8/-
lot of emp prop 6x3 (not for quad!) $5/-
lipo charging board $2/-
3 sets of QUAD 8x4.5 cw/ccw props green, orange & yellow(used) $15/-
turnigy 14awg wire red blue & black total 6m, @1m of black/ red used wire FOC $8/-
futaba servo split wire 60cm $2/-
20mm inrunner cooling fin $3/-
gws brushed motor $1/-
gws inrunner 3S @3500kv from A4 skyhawk kit $10/-
pair of turnigy servo 3ch slow-down regulator $20/-
64mm 10blade + 4mm impeller + metal cone $12/-
Buyers are advised to bring your testing equipment to test before sale, all items 'sold as is' basis... PM me your intentions & contact no.
apc prop 14x7 $2/-
