Hi, Selling the following Trex 600e pro parts:
Each item is listed as part-name/price PER set or pcs/quantity
Item 1: Trex600 Pro Carbon Main Frame (Left)/$25/2 pcs
Item 2: Trex600 Pro Carbon Main Frame (Right)/$25/ 2 pcs
Item 3: Trex600 Pro Carbon Bottom Plate/$10/2 pcs (1 pc with 2 mounting blocks)
Item 4: Trex600 Pro Frame Mounting Block/$10/1.5 sets (0.5 on one of the bottom plate)
Item 5: Trex600 Pro Rear Frame Mounting Block/$10/2 pcs
Item 6: Trex600 Pro Frame Brace Set (CF)/$6/2 sets
Item 7: Trex600 Pro Motor Mount/$10/2 pcs
Item 8: Trex600 Pro Pinion Bearing Mount/$6/2 pcs
Item 9: Trex600 Metal Elevator Servo Mount/$6/2 pcs
Item 10: Trex600 Pro Elevator Arm Set with control shaft/$20/1 pcs
Item 11: Trex600 Pro Metal Main Shaft Bearing Block/$15/2 sets
Item 12: Trex600 Tail Boom Case with Aluminium Hexagonal Bolt/$15/2 pcs
Item 13: Trex600 Pro Metal Reinforcement Plate And Brace Assembly/$15/2 sets
Item 14: Trex600 Pro Receiver Mount/$10/2 pcs
Item 15: Trex600 Pro Battery Mount/$10/7 pcs
PM me if interested, Collection at bedok reservoir road. If want to take all, the price is nego. Thanks.
