WTS: 2 pieces of ESC - hobbywing platinum pro 150a / Turnigy 60a
    hi team;
    looking to sell the following ESC;
    HOBBYWING PLATINUM PRO 150a - $60
    website here;
    1.1 Output: Continuous 150A, burst 220A up to 10 seconds.
    1.2 Input Voltage: 2-6 cells lithium battery or 5-18 cells NiMH battery.
    1.3 BEC: None.
    1.4 Refresh rate of the throttle signal: 50Hz to 432Hz.
    1.5 Control Signal Transmission: Optical/electrical coupled system.
    1.6 Max Speed: 210000rpm for 2 Poles BLM, 70000rpm for 6 poles BLM, 35000rpm for 12 poles BLM.
    (BLM = BrushLess Motor)
    1.7 Size: 88mm (L) * 55mm (W) * 15mm (H).
    1.8 Weight: 125g.
    Turnigy Plush 60a ESC - used , rubber shrink wrap has been removed as I needed to squeeze it into a glider fuse.
    $20
    come with deans connector, not EC5
    Cont Current: 60A
    Burst Current: 80A
    BEC Mode: Switching
    BEC : 5v / 3A
    Input: 5.6v-22v
    Weight: 60g
    Supported motor speed for all TURNIGY ESCs is;
    (Maximum): 210000 RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles).
    any queries pm me.
    price fixed.
    brushless motor: $10
    TURNIGY AerodriveXp
    Model: TR35-42C
    Input Voltage : 7.4V~14.8V (2~4S Li-po)
    Kv : 1100 rpm/V within 10%
    Current capacity : 45A/30s
    Dimensions : 35mm X 42mm / 1.38in X 1.65in
    Shaft diameter : 4mm / 0.16in
    Weight : 132g Number of poles/magnets : 14
    Recommended model weight : 1000~2300g / 35~81oz
    Power equivalent : .30 to .35 IC glow engine
    Suggested prop size: 11x8
    All Turnigy motors come with a 12 month warranty. Suitable for the following model weights; Trainer: 2.5kg Warbird/Sport: 1.8kg 3D: 1.2kg
    no accessories whatsoever. no mounting plate, nothing.
    what you see is what you get.
    motor sold.
    esc still available.
      still got the 60a ESC available.
