Gents,
I'm packing it in and calling it a day. I simply do not have the time or space to keep my RC collection anymore since I am starting a family.
Here's my ware: $400, take everything I got. This includes:
1x WFlyII TX 6ch ( 7/10,some rust on controls but working fine, antenna is also loose but taped works)
1 x FUTABA 4 ch TX 27.45Mhz with Rx (old-skool but works well as well)
1 x B4 Pro batt charger up to 4S
1 x 2200Mah 3S
1 x 1700Mah 3S
1 x 1050Mah 3S
1 x 850Mah 3S
Assorted rods, props and balsa wood.
Aircraft:
1 x 1400mm Skysurfer(7/10 due some knocks and glue but my best flyer so far, has 4ch rx, ESC, servos)
1 x 1000mm Jamara Zero(6/10, no engine, no ESC, No RX, just wing and elevator Servos - for building/static display?)
1 x 880mm wing only of P-51 Mustang (6/10,only survivor of the mustang after multiple crashes, can be re-used for other aircraft projects)
1 x 600mm Sopwith Biplane(8/10, still need to be built, has motor,Servos for wing,elev, rudder, built with Balsa)
1 x JSF(F-35)(50mm EDF motor, 2 servos no esc, all removed but included, 5/10, nose abit bent due crashes)
1 x 2200Mah 3S
1 x 1700Mah 3S
1 x 1050Mah 3S
1 x 850Mah 3S
Aircraft:
