WTS Servos - All for $100
4 x Hitec HS81 (new)
Hitec HS-81 Micro Servo 2.6kg/16g/0.11sec
Motor Type: 3 Pole
Bearing Type: Top Ball Bearing
Speed @ 4.8v: 0.11 sec @ 60 deg.
Speed @ 6v: 0.09 sec @ 60 deg.
Torque @ 4.8v: 2.6 kg.cm
Torque @ 6v: 3.0 kg.cm
Size: 30 x 30 x 12mm
Weight: 16g
4 x Specktrum DSP75 (new)
Spektrum DSP75 1.37kg/7.5g/0.11sec
Modulation: Digital
Torque: 4.8V: 19.0 oz-in (1.37 kg-cm)
Speed: 4.8V: 0.11 sec/60°
Weight: 0.26 oz (7.5 g)
Dimensions: Length:0.90 in (22.9 mm)
Width:0.45 in (11.4 mm)
Height:0.94 in (23.9 mm)
Motor Type: Coreless
Gear Type: Plastic
Rotation/Support: Bushing
2 x Hitec HS65HB (used)
Hitec HS-65 1.8kg/12g/0.14sec
Motor Type: 3 Pole
Speed @ 4.8: 0.14 sec @ 60 deg.
Speed @ 6v: 0.11 sec @ 60 deg.
Torque @ 4.8v: 1.8 kg.cm
Torque @ 6v: 2.2 kg.cm
Size: 24 x 12 x 24mm
Weight: 12g
What you see is what you get.
Motor Type: 3 Pole
Weight: 16g
Modulation: Digital
Gear Type: Plastic
Motor Type: 3 Pole
Weight: 12g
